Dors anyone on here know if its possible to convert 9mm to 15mm on Crossmax SL or SLR wheels?
If so how, where and how much?
cheers
Don't think so definately not pre 2009 wheels, you can tell by taking the QR caps off. If the inside of the hub has a hex bolt inside 15mm won't work. From 2009 crossmax ST's did both QR and 15mm, you simply remove the caps to reveal the 15mm axle. They may have applied this to the SL's and SLR's after 2009 but not sure but its easy to check. They don't do conversions for the older stuff.
Its not.
cheers guys........i'll have to pass on a nice pair of fox forks now! 🙁
I had some 15mm adaptors made for my Crossmax XL
Crossmax xl is possible because they have a hub wide enough for 20mm. Totally different hub on the Sl's and Slr's. 😉
I have a pair of Crossmax SLRs and 15mm Fox forks, you just need to take the 9mm spacer thingy out.
the bone- i'd be interested in how this is done, could you email me?
cheers
