Any other users of the Mavic Aksium 2010 wheels having problems with what appears to be loose bearings or something. Mine has a very slight bit of play when the QR is closed really tight, i'm presuming this isn't normal so i'm going to try and strip it down and re tighten the hub and hope that cures it. Also the QR that was supplied with both front and back has about 1mm difference to the hole in the axles, again is this normal or is this why i'm getting that movement?
QR is only to provide tension against the frame, wouldn't worry about a bit of play inside the axle.
The aksium hubs are adjustable tension similar to cup and cone style hubs, even though they have cartridge bearings.
