Mavic 719 alternati...
[Closed] Mavic 719 alternative?
[#1283125]
CRC have been out of stock for ages on the 719 rim, any recommendations for something else of a similar Ilk? Weight is important as is strength
Moon on a stick?
Yes, two for me please
Posted : 01/02/2010 10:58 pm
Tried other retailers?
Posted : 01/02/2010 11:02 pm
Evans have stock
but a few quid more
Me I am waiting for crc
two for me to
Posted : 01/02/2010 11:03 pm
You don't have to use disc specific rims... CRC have 32h non-disc 719 rims in black for only £34ea.
Posted : 01/02/2010 11:04 pm
Want rims built onto wheels, nobody else comes close to the price
Might just wait it out as I dont need them that urgently
Posted : 01/02/2010 11:05 pm
Are there any alternatives to the 719's as I would be interested to find out what say the equivalent DT swiss rims are. 😕
Posted : 01/02/2010 11:29 pm
I got my ones built by Merlin last year, hang on.
Yep, they have them in stock. If youre going for a built wheel from them i would be surprised if they arn't just as cheap if not cheaper.
Posted : 02/02/2010 12:14 am
Nobody comes close? Whenever I've bought or price checked wheelbuilds merlin usually works out cheaper than CRC
XM719 (non-disc) is heavier than XM719 Discs
Posted : 02/02/2010 12:17 am
email CRC? They'll know when the stock's coming.
Posted : 02/02/2010 12:24 am
LBS?! I know mine refuses to get beaten by CRC out of principle!
Posted : 02/02/2010 9:41 am
When I last bought wheels I think CRC were the same price but with better spokes?
Posted : 02/02/2010 10:15 am
CRC are cheaper when you upgrade spokes, and Merlin dont have the 20mm SLX hub available either.
A boy I know might have the answer though 🙂
Posted : 02/02/2010 10:59 am
phone them they are very helpful.
I have orderd a few non standard wheels from them.
Posted : 02/02/2010 11:16 am
Just looking at other rims available on CRC, and the Sun Ringle EQ23 look like a comparable rim, and nice and light. The 27 are a little heavier but look more burly.
Posted : 02/02/2010 12:27 pm
EQ23s are not quite as burly, nor as wide as the Mavic 719. I have a set on my Trance - for fat boy xc, have been pretty good so far.
Posted : 02/02/2010 12:34 pm
Stan's Arch?
if it's still available
Posted : 02/02/2010 12:37 pm
LittleTones - What tires size can they take up to? Fat Boy xc is what I sort of want. Fatboyxc/allmountain"lite"
Posted : 02/02/2010 3:19 pm
I have DT XR4.2's on DT240 hubs and I destroyed the rims 1st time out. 15st and a hard tail in the peaks. Not strong enough for that so steer clear.
Posted : 02/02/2010 4:06 pm
Here you go, a good bit cheaper than CRC as well - http://www.jejamescycles.co.uk/mavic-xm719-disc-item132449.html
Edit: Ah sorry just read the thread properly, I'd say go for a Hope Hoops factory build from Winstanleys.
Posted : 02/02/2010 4:11 pm
Cheers schrickvr6
But I was looking for a pair of wheels built up.
Though If i got the rest of the bits cheap I could do it myself, but it will undoubtedly work out more expensive, given the price of blooming spokes now
Posted : 02/02/2010 4:15 pm
What hubs are you wanting to use?
If it's Pro 2s check out The Bike outlet for good prices, also Spa Cycles for well priced Sapim spokes. If you can build them yourself which isn't that difficult and very satisfying I'd imagine the price would be close.
http://www.bikeoutlet.co.uk/index.php?p=catalog&mode=manufacturer&mid=9
http://www.spacycles.co.uk/products.php?plid=m2b0s156p0
Posted : 02/02/2010 4:23 pm
BK - I've got Specialized Resolutions on them at the moment, so high volume 2.1 tyres. Have used Bontrager 2.2,and they will probably go up to normal 2.3 / conti 2.4s. They've been good so far, but I do ride in the south without too many rocks, but they are quite light. I'm 16 stone and didn't bust them over the course of 2009. CRC made the wheels with Disc Jockey hubs. They were cheap at the time, but they are not so cheap now. Up until these I've always had wheels built with F519/XM719 rims, bought these to try and cut down on weight.
Hope that helps.
Posted : 02/02/2010 4:39 pm
Cool. I might go for the EX27's then and try a new rim for a change. They sound like they will cope ok for me if they are that little bit wider and little stronger than the EX23's
Posted : 02/02/2010 5:41 pm
CRC now have stock I have just ordered a pair
Posted : 02/02/2010 7:15 pm
Sweet, ordered
SLX 20mm front hub and QR rear... DT Comp black spokes, 719 disc rim - £150
**** me thats cheap
Posted : 02/02/2010 8:40 pm
Just got the 719's delivered
wheel building for me tomorrow
Posted : 05/02/2010 7:23 pm
