Mavic 521 burping/r...
[Closed] Mavic 521 burping/rolling tyre off - help, please........
 core
[#6416873]
I'm running a Butcher up front a Purgatory out back, both 2.3, on Mavic En521 rims with Stans fluid and rhino rim strips, with cloth tape underneath, as spec.
The rear has been fine, but I'm having a lot of issues with the front, I keep the pressure pretty high (approx 40 psi) as I'm not the lightest (15 1/2 stone), a clumsy (ish) rider on a hardtail.
It just keeps on burping/almost popping the tyre off, they are quite thin/flexi sidewalls, but it's getting to be a right pain in the arse. Last night it happened, on a very slow, very steep, rough descent, where front brake had to be used (barbed wire on side, gate at bottom), as soon as I got on the brake, tyre just rolled over and..... hisssss, out came half the air.
So, any ideas folks?
p.s. see old thread with similar comments: [url= http://singletrackworld.com/forum/topic/tubeless-mavic-en521-ghetto-joes-strips-or ]HERE[/url]
Posted : 15/08/2014 1:49 pm
Not much help but, I have the same rims with On-One Smorgasbord tyres and tubeless with Joe's No Flats. Been fine for me and I am not easy on the wheels!
Posted : 15/08/2014 2:20 pm
I've never had a tubeless conversion I was totally happy with, except for the DT ones which are designed for the rims. Not helpful I know but I gave up on tubeless without proper tubeless rims.
Posted : 15/08/2014 2:24 pm
you could try some extra tape under the rim strips to make the bead a tighter fit?
Posted : 15/08/2014 2:25 pm
 core
I suppose I could, but not sure if/how it would make any difference, as the sidewall rolls over, the tyre deflects a lot, and burps on the opposite side, perhaps it would make them that bit tighter on the rim and stand more chance of holding air.
Or, I could just stick a tube back in...........
Posted : 15/08/2014 2:36 pm
