Has anyone got a copy of the pdf servicing manual I cannot find it on line
My forks need a service and I cannot remember the oil levels
Thanks lads but can you open the pdf file for servicing because I cannot
Yes but its taking about 30 seconds per page.
[i]Once the parts are reassembled, fill the empty
Damper Tube with 5wt oil. The amount
of oil is determined by the level it is
from the top of the empty Damper Tube.
The correct level is 63 mm from the
top of both the DUC & SC.
Face the Schrader Valve upwards and cycle
the cartridge, then pressurize the Damper
Cartridge through the Schrader Valve at the
bottom to 60 psi.
DAMPER TORQUE VALUES
Piston Nut: 50 in/lbs Blue Loctite[/i]
Got it thanks lads
