Marzzochi 44's
[Closed] Marzzochi 44's
[#3474544]
So I've just had my 1st ride on my new 2010 Micro Ti's and they are great. However, i can't help thinking they are moving under normal riding a bit too much & dive when the front wheel is applied, the psi is set at the maximum they recommend & they are lovely & plush.
I had this happen on my Manitou Minutes & the solution was to change a spring (don't ask me which one as i don't know too much about the inner workings of forks) to an x-firm one as they come as standard with a medium one.
My question is can i do this with my 44's. Do they have such a spring in them?
Posted : 18/12/2011 10:36 pm
They must have some sort of low speed compression adjuster you can... adjust?
Posted : 19/12/2011 1:40 am
Use the air volume adjust or fiddle with the Micro TST thingy on the left leg
Posted : 19/12/2011 8:34 am
Have a read through this for a few tuninng tips.
[url] http://forums.mtbr.com/29er-bikes/marzocchi-44-revisited-625743.html [/url]
Posted : 19/12/2011 10:38 am
