Hi I have a set oz Marzocchi z4's from 2001 in my inbred, the manual gives recommended air pressures but does not state if that is shared over both legs or each leg, eg 90psi in each leg or 45psi in each totalling 90psi
Posted : 01/05/2021 6:15 pm
IIRC they’re low pressure forks. 45psi per leg sounds right although that’s quite a bit more than mine were - think they ran at nearer 30.
Posted : 01/05/2021 7:05 pm
