Marzocchi 'Maxle' F...
[Closed] Marzocchi 'Maxle' Feels Loose?
[#458937]
Got a problem with my AM SLs. Even with the 20mm QR done up as tight as possible, there is still a scary amount of flex/wobble in the front wheel and you can hear it 'knocking' as if there isn't something quite right.
Anyone else has this experience and if so, whats the fix? A new QR axle thing would be my assumption but I'm not sure!
Dave
Posted : 08/04/2009 9:09 pm
is it your hub?
Posted : 08/04/2009 9:34 pm
Nope - had some 36s before my Marzocchis and it was rock solid so I can only assume its the QR axle assembly thing.
Posted : 08/04/2009 9:36 pm
 IWH
Seriously, check the hub bearings. It's more likely to be that than the axle. Don't forget that it only takes a tiny bit of play in the bearings to make it feel like a serious issue when you wiggle the rim.
Posted : 08/04/2009 9:39 pm
But it was literally fine with the 36s, then 5 minutes later ****ed on the 'Zocchis. No gradual problem...
Posted : 08/04/2009 9:41 pm
 IWH
Are they a brand new set of forks?
Posted : 08/04/2009 9:54 pm
Nope, 2007s
Posted : 08/04/2009 9:57 pm
Are you tightening it in the right sequence? You need to remove the end float first then tighten the axle clamps. so tighten one clamp - then tighten the bolts on the end of the axle then tighten the other clamp
Posted : 08/04/2009 10:04 pm
There are no bolts - they're the 20mm QR versions.
Posted : 08/04/2009 10:14 pm
Same principle - you need to take the end float out first then clamp the axle in the drop outs.
Got a pic so I can see the exact type? I have 2 different 'zocchi systems one called qr 20.
Posted : 08/04/2009 10:20 pm
I'll go and take another look at em and get a pic if they're still giving me a headache.
Cheers mate..
Posted : 08/04/2009 10:22 pm
 Doug
You need to screw the QR adjuster in a bit. This is found at the other end to the QR lever.
Or maybe it's ****ed.
Posted : 08/04/2009 10:27 pm
Found it on the net - is there a threaded bit at the end opposite the lever like a maxle? srtip clean and relube it all. tighten the threaded bit by hand before flipping the lever.
Posted : 08/04/2009 10:29 pm
