Marzocchi 55CR - Sp...
[Closed] Marzocchi 55CR - Spacer installation
[#5734322]
Hi
Just bought Marzocchi 55CRs 170mm but looking to install the supplier 20mm spacer. Does anyone know how to do this?
Posted : 29/11/2013 7:33 pm
Yes, I've done a couple and there are no manuals. I did it my "tinkering". As a result, I now know that if you let the oil out of the damper, you have to bleed it under oil (search YouTube for a how to) otherwise the rebound doesn't function.
The only useful bit I remember is that to get the spacer on, there's a fitting on the bottom of the rod that's just a push fit. Don't look for anything more cu ni g that that!
Posted : 29/11/2013 7:54 pm
