Marzocchi 55 RC3 Ev...
[Closed] Marzocchi 55 RC3 Evo travel lowering
[#6876305]
Can these be lowered from 170mm to 160mm ?
Posted : 20/02/2015 1:28 am
Nope, well that what I was told by wind wave.
Posted : 20/02/2015 6:12 am
Yes but it looks a faff.
I've got a set and have looked a lowering them. It looked a load of hassle so I just left them at 170mm. They are brilliant.
You can push them down and let air out of the air preload. This does lower the front by about 10mm on mine. Someone on here recommended it. I tried it and it was fine.
There is a thread about how to do it on mtbr but I can't find it.
Try here
http://forums.mtbr.com/shocks-suspension/lowering-2012-marzocchi-55-rc3-evo-ti-fork-818468.html
http://forums.mtbr.com/shocks-suspension/oil-levels-lowered-marzocchi-55-rc3-ti-evo-818545.html
Posted : 20/02/2015 9:43 am
tall_martin - Member
That's what I do with mine - it lets them ride a bit deeper into their travel, which, as I'm borderline for the stock spring being a little too heavy, does the job for me.
I suppose I should try the light spring, but not at £179.
Posted : 20/02/2015 9:52 am
Thanks guys really would love to have these forks but would my frame wouldn't be warrantied with them on.
Anyone had comparable rides with the recent coil 160/170mm lyriks?
Posted : 20/02/2015 10:59 am
Then get them but don't tell anyone....
Posted : 20/02/2015 11:23 am
you can different springs for these? Where?
Posted : 20/02/2015 11:51 am
Interesting. I could do with a firmer one. And a spring too! Ho ho ho. Where? TELL US!
Posted : 20/02/2015 11:59 am
dbcooper - Member
You can get a softer one [url= http://www.ukbikestore.co.uk/product/353/y8501473/marzocchi-55-rc3-ti-170mm-soft-spring.html ] here [/url].
I don't think they make a firmer one.
Posted : 20/02/2015 12:04 pm
jontykint - Member
If you're worried about warranty issues with 170mm 'zokes then surely the same would apply for 170mm Lyriks?
And like I said - who'll know about that extra 10mm anyway - the Fork Travel Police are hardly going to drop in for a surprise check, are they?
I doubt my Alpitude frame is "warrantied" for them either but I really couldn't care less, I can't see me breaking it and the forks are worth more than the frame anyway.
Posted : 20/02/2015 3:58 pm
Is your frame 160mm travel? If so don't worry about it.
140mm? Maybe more dodgy.
Posted : 20/02/2015 5:43 pm
Loco lowered my 44 RC3Ti's by 10mm by putting a spacer under the negative spring. Pretty sure you can do the same thing with 55's.
Posted : 20/02/2015 5:50 pm
Yea the frame is 160mm so not too much difference.
Not that worried about the fork police, but an Alps trip could prove to be costly if I knacker the frame in.
The lyriks can be set to either 170 or 160mm straight from the box.
I will maybe get in touch with loco or something to check before pulling the trigger on the zokes
Posted : 20/02/2015 8:39 pm
But what difference do you think 10mm is going to make to the likelihood of you knackering your frame? Non, that's what.
And if it does break just say you had a set of 44's on it. Who'll ever know?
Posted : 20/02/2015 9:26 pm
I had some and run them with no air pre-load, plush as
Now have 160mm pikes now which are similar and surprisingly good in comparison, always been a coil user before.
Crown to axle is more important to consider than travel for geometry
Posted : 20/02/2015 9:41 pm
It's not the 10mm I'm worried about its my inevitable stupid line choices in the Alps that are gonna cause the problems!
But then the marzocchi will help me out in that regard better than any other fork.
F it I'm getting them !
Posted : 21/02/2015 12:44 am
