Marzocchi 55 numpty...
[Closed] Marzocchi 55 numpty question
[#5588363]
Is it true that the forks are deliverd requiring a top up of oil ? Have just spent some wedge on them and I don't want to bugger them within a few rides. Not sure if my older and wiser mates are having me on or not
M
Posted : 10/10/2013 4:12 am
They have had a history (along with nearly all fork manufacturers) of getting some of the factory oil fills wrong - too much/little by batch.
Generally they will not feel right with the wrong volumes (or feel better as the factory volume was not suited to you as a rider). Oil level is in some cases just lubricant and in others it's another tuning dial.
The manual will tell you if you need to fill with oil as a factory directive. If you open them and change the oil you can put in the "Factory specified" volume but again with Marzocchi this could be plucked from thin air.
Posted : 10/10/2013 4:16 am
