Marzhocci Shock Pro...
[Closed] Marzhocci Shock Problem - valve pin too short
[#1715903]
My fox pump doesn't allow me to pump my Marzhocci shock,
Even if I screw it on fully the pin within the shock valve doesn't compress enough to allow air to be pumped in.
Anyone got any cheap suggestions, I don't want to shell out £30 on a new shock pump, will one of those valve extenders work? Also doing a google search there is a "Marzhocci adaptor" but that seems to be something else.
Suggestions please.
Posted : 17/06/2010 11:40 pm
Is it a schraeder valve ? Maybe try a replacement core ?
(Marzochi adaptors are for a narrower valve than schraeder, though might take the same core)
Posted : 17/06/2010 11:46 pm
Yep, schraeder valve, new core was my first thought, or at least unscrew this one a couple of turns....
Onto CRC then for replacement and remover.
Posted : 17/06/2010 11:56 pm
typing 'marzocchi' might help.
Chances are you'll need a new pump anyway. Marzocchi forks run lower pressures than RS or Fox so you might have issues getting the pump off when it does work, as well as a not to accurate reading on the dial.
Posted : 18/06/2010 12:00 am
A good point well put Bommer! Its quite late and brain in't working!
But if you took the time to read my original post you will see it is for a shock not a fork, therefore my Fox pump will be adequate if I could get it to work.
Posted : 18/06/2010 12:04 am
