Marz' MX Comp ...
[Closed] Marz' MX Comp travel question ?
[#2376453]
04' MX Comps (air sprung), 105mm travel versions.
Can the travel be increased to 120mm ?
I know they are old hat nowadays, but these have only ever seen a couple of rides.
Posted : 17/01/2011 1:25 pm
Yeah I think they can be increased to 120mm, there is this manual for 06. it might be the same
Posted : 17/01/2011 1:33 pm
Internal Spacer change I believe....
I have some 03s set to 90mm I think, they need an oil change and fiddle, I may look at it when I next have them apart...
Posted : 17/01/2011 2:01 pm
Well what d'ya know...
Good ol' STW.
Posted : 17/01/2011 2:41 pm
 jonb
I may have the manual for the 04 versions on another PC. It's available if you google, if not and you want it drop me an email (bayley.jon @ gmail .com) and I'll see if I can find it.
Posted : 17/01/2011 4:21 pm
 Olly
Oh dear.
my 456 with MXcomps at 105mm, that ive just retired, just came out of retirement.
Posted : 17/01/2011 4:32 pm
Did the same for my mmmbop....what a shame they just underclocked these reliable little forks
Posted : 17/01/2011 4:43 pm
Sorry for the hijack but any tips on changing the press-in bushes & seals on thes forks as Mrs imp's need doing?
Ta.
Posted : 17/01/2011 5:00 pm
They're not press in, they're slide in pre '04 IIRC, just take the seals out, pull the bushing out with your fingers (its a long thin walled tube coated in teflon, with a slot in it and a lip at the top), slide the new ones in in the same way, pop new seals in, put it all back together and jobs done, its only 2 min more work than just doing the seals on the older forks and no tools needed.
Posted : 17/01/2011 5:42 pm
 Olly
just done it to my 2005, air-on-both-sides MXCs.
Fork apart, swear at circlip, shout at circlip*, win vs circlip, remove spacers, chuck back together, replace oil, pump up, jobs a goodun.
Piece of pee.
Ill get some photos up soon, just need to wash the oil off the living-room first.
*if the bicycle was mans greatest achievement, the circlip, was certainly his darkest day
Posted : 18/01/2011 8:41 pm
