On my 7.3 there is a nut either side which switches the geom, at the moment I would say it's on the longer, what benefit would I have if I moved it?
Posted : 01/03/2014 8:31 am
here we go, from the MBR review
The Quake has adjustable geometry. The ‘Low’ position slackens the head angle to 66-degrees and lowers the bottom bracket to 13.9 inches; the ‘High’ position steepens the head angle by a degree to 67-degrees and raises the bottom bracket to 14.5 inches
Read more at http://www.mbr.co.uk/products/marin-quake-ltd-edition-frame-999/#7XE5tmTjLADgoV0Q.99
Posted : 01/03/2014 8:54 am
Thanks, what would be the benefit of both? The lower more travel? The higher less? What situation would you change it
Posted : 01/03/2014 9:15 am
