Marin Lifetime Warr...
[Closed] Marin Lifetime Warranty and Second Hand Frame
[#321406]
The bearings are shot on the back of my Dads Marin, however it's a second hand frame bought from Leisure Lakes a few years back. Has anyone had their bearings replaced on warranty for a second hand frame? It seems like it will be an expensive do otherwise! Thanks
Posted : 19/02/2009 8:38 pm
No but not sure about whether you can as its second hand - did you register it? If not could probably do it yourself as you can get the bearing sets online depending on model?
Posted : 19/02/2009 8:39 pm
My LBS has done two different s/h Marin frames for free, but the KP7 bearings are only a couple of quid each if they don't.
Posted : 19/02/2009 8:43 pm
i have it on good authority they will replace bearings on second-hand frames, yes!
Posted : 19/02/2009 8:47 pm
I might well be contacting them tomorrow re warrenty issues!
Posted : 19/02/2009 10:07 pm
looks fine to me mate........
i'm sure the rohloff will 'invalidate' your warranty!
Posted : 20/02/2009 12:26 am
Never seen one break there before, but I've broken one or two Marin swingarms in the past and always found the service from ATB sales to be excellent, I understand it depends on your Marin dealer to a certain extent though.
Posted : 20/02/2009 12:50 am
I think they'll be OK, they changed this one last year & it was 9 years old![img] [/img]
Posted : 20/02/2009 12:58 am
Lifetime warranty usually only applies to the original purchaser with the original receipt - they will want to see the receipt, so if you have that with the bike you should be ok?
I had a similar thing with a cracked specialized fsr frame, 2nd hand, but with no receipt no warranty 😥
But, as mentioned the bearings are cheap and easy to replace anyway and your LBS should have no problems doing them 🙂
Posted : 20/02/2009 9:50 am
That's an incredible pic! I'd be REALLY PROUD if I'd broken a frame like that!
Posted : 20/02/2009 9:56 am
Whats to be proud of? (mine was 5 years old when replaced)
[img] http://images.fotopic.net/?iid=y7z9do&outx=760&quality=70 [/img]
Fanatastic frame dead, I wasn't happy but was more than happy with ATB/Marin's service & the replacement provided ..
I've also had a swining arm fail at the end of the welding (18 months).
Should I mention the previous frame that died with a crack on the downtube...
Posted : 20/02/2009 10:03 am
