Marin attack trail ...
[Closed] Marin attack trail front mech question
[#285767]
Hi all,
I was hoping someone could advise me of the size of clamp I need for an 07 Marin attack trail ans if it is top or bottom pull, I think it is bottom.
Cheers,
Englishmastiff
Posted : 08/02/2009 1:12 pm
Mines the older shape quad link & its 34.9mm bottom pull.
Posted : 08/02/2009 1:13 pm
snaps,
Thankyou. I am building from scratch. I had an idea that was the one so thanks for the confirmation.
Posted : 08/02/2009 1:18 pm
If it's one of the older style frames, and new old stock, you may find the cable guide under the bottom bracket is mounted in the wrong hole. If it is and you dont relocate it, you are likely to have your cable eat into the bottom bracket shell. Worth a check when you build it! I noticed it when i built a new Wolf Ridge frame!
Posted : 08/02/2009 2:23 pm
