Manitou Tower Pro 1...
[Closed] Manitou Tower Pro 15mm QR stuck
[#6021878]
I have a 3 month old set of Manitou Tower pro with 15mm QR Hexlock axle.
When I release the QR, turn it 1/4 turn, it will no longer pull out. Any ideas?
Posted : 09/03/2014 2:35 pm
I've got the older ones with the pinch bolts , they need loosening first .
HTH .
Posted : 09/03/2014 2:49 pm
Once you've undone the qr, can you loosen the little silver wheel which sits behind the qr (not sure if that actually makes a difference as I've only had mine a week)
Posted : 09/03/2014 4:57 pm
Yes, the silver tightening nut still works, I just can't extract the QR. The 1/4 turn should disengage the licking lugs, and it should just slide out. No issues before, but today it won't budge.
Posted : 09/03/2014 6:27 pm
Cheesy - no pinch bolts on the hexQR version.
Eventually unscrewed the cap on the non QR side, and punched out the axle. It looks like it was a lack of grease, and the tight tolerances of the Hex Axle just held the axle tight in place.
All greased now, and works fine :-))
Posted : 11/03/2014 2:57 pm
