Manitou Swinger 3 W...
[Closed] Manitou Swinger 3 Way to RP23
[#2929248]
I have just bought an RP23 to replace the Swinger on my VT2 and wondered about the actual mounts. Can I bolt one off and the other on (both 190 by 50), or will it not be that simple?
Many thanks,
Dom.
Posted : 09/07/2011 6:47 pm
The bolts are the same but the top hats/bushes are different, don't know the actual sizes though, your rp probably has bushes in, you'll need new top hats the correct width for your frame
Posted : 09/07/2011 6:55 pm
No (to the OP) you'll need a new mounting kit, the manitou use a 12mm bushing & mounting kit, and the fox a 12.7mm bushing & mounting kit.
You need to measure the current mounting kit to order a new one (bolt size and width of the mounts), from the likes of TF Tuned, Betd, Loco(?)
More info: http://www.tftunedshox.com/info/mount_kits_bushings.aspx
Though Wow! Tf tuned's new webguide, makes it easy & supplies the details:
http://www.tftunedshox.com/MountKitGuide.aspx
Posted : 09/07/2011 6:58 pm
Thank you for your helpful replies. I will check out the links and give TF a ring if I get stuck!
ATB, Dom.
Posted : 09/07/2011 8:06 pm
