Manitou Minute arch...
[Closed] Manitou Minute arch rub
[#2447575]
Has anyone had this happen to their Manitou fork arch? Perfectly even on both sides...
More pics here: http://s1215.photobucket.com/albums/cc515/guando21/Manitou/
Went for a few muddy rides where it caked around the arch for maybe 5 mins at a time before being scraped off...new front hub, no play in bearing/axle etc...
Is this common? 😕
Posted : 07/02/2011 9:01 pm
 IA
Can happen on all forks, how wide a tyre?
Posted : 07/02/2011 9:03 pm
2.3...measures 58mm, the manual says max tyre width 63mm
Posted : 07/02/2011 9:30 pm
Happened to my old minutes. The reverse arch design is narrower than most, so a bit more prone to it.
Doesn't really cause a problem though. I wouldnt worry about it if I were you.
I thought the reverse was supposed to give better clearance?
Posted : 07/02/2011 10:58 pm
