Make it stop...
[Closed] Make it stop...
[#669894]
Rode some very over grown singletrack yesterday. Legs looked awful yesterday with scratches and nettle stings and are still stinging/itching nearly 24hours later. I need something to stop the itching before it drives me mad. What's the best tried and tested method for nettle stings and bramble cuts?
Posted : 29/06/2009 12:06 pm
Witchazel
Posted : 29/06/2009 12:07 pm
Dock Leaf for nettle stings, and Aloe Vera or Germolene for small cuts.
Posted : 29/06/2009 12:08 pm
Best tested method here is shin pads 😉
Other than that Aloe vera gel seems to work for everything.
 Sam
Oatmeal milk works pretty well for a very cheap solution. Otherwise any manner of anti-sting stuff from a chemist (stingose etc) I'm sure work fine as well.
Posted : 29/06/2009 12:09 pm
Get a tube of WTFU cream. Works wonders. :p
Posted : 29/06/2009 12:11 pm
Cold water compress - soak some paper towels and then dab your legs...the cold seems to help relieve the itching without actually itching...not a long lasting fix though...
Posted : 29/06/2009 12:12 pm
tried aloe vera yesterday, helped a bit - took some of the welts down anyway. will try to get some witchhazel from the chemist at lunch for rest.
*scratches legs like mad - still debating whether the singletrack was worth the pain!!
Posted : 29/06/2009 12:14 pm
Get the gel if you can d/girl. Smells nice in a wierd kinda way too..
Posted : 29/06/2009 12:16 pm
They're just stings - not very bad ones at that.
MTFU is not appropriate in this case. Its GTFU. 8)
HTH.
Posted : 29/06/2009 12:17 pm
MTFU cream wont work.
Try WTFU DermaTat, it has added Proretinolplumpingcollagenical Peach extract and 75% of women became noticeably less Jey after just 10 days use (Survey size of 12 women)
LOL @ Stoner...
Posted : 29/06/2009 12:18 pm
i actually quite enjoy the feeling of nettle stings. Makes one feel ALIVE!
Posted : 29/06/2009 12:26 pm
scienceofficer, how do you know they aren't that bad - have you been looking at my legs this morning?! 😀
don't think its the stings that are bad, its the cuts, which look fetching in my skirt today!
Posted : 29/06/2009 12:27 pm
sorry, it has to be done...
this thread is useless without pics... 😉 !
Posted : 29/06/2009 12:43 pm
"don't think its the stings that are bad, its the cuts, which look fetching in my skirt today!"
Yep I think the STW collective should be the judge of that... 😛
Posted : 29/06/2009 12:47 pm
Lol @ stoner.
I find spitting on your finger and then rubbing that into the sting is a good temporary fix. not much you can do about the scratches other than wear them with pride though 😀
Posted : 29/06/2009 12:50 pm
Dab them with vinegar.
I think Charlie the bikemonger has some tips on nettle stings.
Posted : 29/06/2009 12:51 pm
Anthisan. Bite/sting cream, available from Boots etc.
Posted : 29/06/2009 12:55 pm
Anthisan for bites/stings plus an antihistamine can help.
If the main problem is the scratches/cuts get some germolene on them - same kinda stuff as Savlon, but has a local anaesthetic in it too. If you use it regular (few times a day) it helps them heal quicker too, as I found a couple of weeks ago on a large gouge I took out of my arm.
Posted : 29/06/2009 1:00 pm
Just hurt yourself properly - you'll completely forget about the minor scratches. How about separating your shoulder - that stings a bit. Or take a chip out of your shin with an spd.
Posted : 29/06/2009 1:02 pm
I'll tell you what doesn't work...ammonium based fertilizer, damn that stuff makes bramble cuts sting!
Posted : 29/06/2009 1:17 pm
