Magura Vidar Help!
[Closed] Magura Vidar Help!
[#347227]
Hi guys,
I ride rigid, but a mate has a set of Vidars knocking around that are mint and I thought for £20 it would be nice to have the option to bang a set on my bike now and then.
The problem is they are very soft and I want to stiffen them up a bit. Can I do this with a heavier weight oil or do I need a firmer spring? Where can I get one if so.
I weight in about 17 stone and I am 6'3. The Vidars are the 80mm travel version.
Cheers in advance for your help.
Tom
Posted : 27/02/2009 1:39 pm
[url= http://www.bikeradar.com/gear/category/components/forks-suspension/product/vidar-10237 ]According to this they are air sprung[/url]
Posted : 27/02/2009 1:46 pm
My Vidars OEM ones where coil and had preload adjust only. Great cheap forks though.
Posted : 27/02/2009 2:10 pm
Oil weight just changes the damping not how hard they are. If they are coil sprung (ie have a metal spring inside) then you can either wind up the preload or change the spring. If they are air sprung then you just pump em up.
Posted : 27/02/2009 2:22 pm
