Magura Marta rotor ...
[Closed] Magura Marta rotor compatibility problem
[#3938350]
Could I pick the collective STW brain please?
I've recently acquired an Alfine equipped wheel to provide an easy swap between singlespeed and gears. This came with an Avid 160mm rotor. My bike has Magura Marta 160mm front and rear. The problems is that Avid rotor just catches the inside of the caliper.
Does anyone have a solution or know which other rotors will fit the Marta caliper? The correct Magura one is the obvious answer but they're £40 new and like rocking horse poo second hand. If anyone happens to have the correct Marta rotor (wavy with a very narrow braking surface) I'd love to hear from you.
Thanks for your help
Andy
Posted : 03/05/2012 10:48 am
Anyone...?
Posted : 03/05/2012 6:33 pm
I have some formula rotors on marta sl mags. They work fine.
Posted : 03/05/2012 7:20 pm
Shimano centre lock work! slx or xt or xtr, deore work too! I've used them all and used martas for 5 years. alfines for 2 years too.
timax
Posted : 06/05/2012 9:36 pm
