Magura Louise
[Closed] Magura Louise
[#856532]
the pad retaining pin is stuck and the allen key socket (2mm) has rounded
whats the better way to remove it, with an easy out, or cut a slot in the other end and screwdriver, or is there something else?
Posted : 10/09/2009 1:57 pm
Here's my technique on Marta SL's
Using snipping pliers, snip through the pad backing that the pin passes through, remove the pads.
Use monkey wrenches on the pin - having removed the pads, you'll now have enough room for locking pliers to fit onto the pin.
If you dont get enough grip on the pin, use a small piece of emmery cloth with the grit side against the pin.
Still not budging? I've used a soldering torch to gently warm the caliper.
When refitting - dont over tighten 😉
Make sense?
Posted : 10/09/2009 3:32 pm
