Magicshine Q
[Closed] Magicshine Q
[#2352921]
I've had my magicshine light for a while now and until now it's been pretty good.
It died yesterday morning, thought the battery may need charging, so charged overnight (the red light has never changed colour on the charger so there may have been a problem with that) connected it up this morning and got about 3 minutes out of it.
so, what's more likely to be goosed? Battery or charger? I'm thinking the battery.
Are the new MS batteries any cop?
thanks in advance.
Posted : 10/01/2011 10:12 am
Can I have it I want a dead one to mess around with .
most likely the battery is goosed Smudge does replacements
Posted : 10/01/2011 10:29 am
yeah sure, no problems, as long as you don't mind me chopping the plug off.
cheers
Nikjohnson(at)btinternet.com
Posted : 10/01/2011 10:36 am
Its not the battery I want I want the light head to put an XML Led in it to see if it improves the output
Posted : 10/01/2011 10:53 am
I've found that they are particularly susceptible to shorting out around the point where the wire emerges from the flex-protector on the plug. Twisting in this area seems to be the failure mode. The both outer casing and the inners seem to be too brittle.
I've reinforced this area on both battery and lamp ends with a liberal dose of self-amalgamating tape to give it better flex protection. Seems to have done the trick.
Take a closer look at that area before you scrap 'em. You may find its recoverable.
HTH
Posted : 10/01/2011 11:55 am
trout - Member
POSTED 1 HOUR AGO # REPORT-POST
Smell an upgrade?
Posted : 10/01/2011 12:03 pm
Trout, I've got 2 so could bear to lose one for a while if it's being upgraded 🙂
Posted : 10/01/2011 12:05 pm
Even though I'm a Yorkshireman and have lived in the Dark satanic village with a 'Duck Crossing' they call Silsden 'cos I was too mean to buy a house in Ilkley I'd even pay, yes pay to have the light upgraded 🙂
Posted : 10/01/2011 12:07 pm
Tiger I am game but cant make any promises it will be a huge improvement .
and if you have 2 then a good man for a comparison .
I will drop you a mail with my addy on I only need the lamp head not the battery or charger .
Posted : 10/01/2011 12:11 pm
lovewookie,
If youre not sure if its the battery or charger, you can post both of them to me to check over, or im pretty sure Troutie has a 2S charger he can check youre battery against to see if its working or not.
Posted : 10/01/2011 7:40 pm
Thanks Smudge.
Thing is, I'm not convinced the battery was ok from the start. I've only ever had 3 hours run on low settings and the light on the head unit button has never been green, the charger has never been green either. Could well have been knackered from the start, eh?
Posted : 10/01/2011 9:03 pm
No problem, post me the battery and we'll take it from there.
Posted : 10/01/2011 11:39 pm
