magicshine gopro ty...
[Closed] magicshine gopro type light mount?
 jsm
[#8041192]
My new helmet has a gopro style light mount capability. anyone know if there's a magicshine type one?
[url= ]like this[/url]
ta,
stu
Posted : 07/09/2016 4:00 pm
http://www.gearbest.com/led-accessories/pp_240917.html?wid=21
Just unscrew the mount from your existing light, all mine have had the same screw/thread. Just add some silicone sealant around wires etc, as sometimes the wires come through the rubber of the mount to seal them.
Posted : 07/09/2016 4:38 pm
Afaik, that's not the most secure/ least wobbly light mount.
There will be plenty more people with more sensible suggestions, but in the meantime, try searching for go pro skateboard mounts.
You unscrew the o ring mount from your magicshine and replace it with the skateboard style mount.
Edit...as above 😳
Posted : 07/09/2016 4:41 pm
I've made a bodge up previously but just ordered the gear best ones.
Thanks for the link
Posted : 07/09/2016 4:45 pm
The screw to the light is fine, the only issue is there's less friction between the two parts of the go-pro mounts, because it's aluminium an go-pros are plastic.
It works fine in a plastic mount (i.e. a go-pro one), less well in a aftermarket aluminium one, easily solved by putting a layer of electrical tape on each side of each of the fingers to give it something to compress when tightening the addapter.
Posted : 07/09/2016 5:29 pm
Theres a few on thingiverse, I could print which ever one you want for £4 posted.
Posted : 16/09/2016 8:07 am
http://www.thingiverse.com/thing:197074
Posted : 16/09/2016 8:09 am
Hexhamstu - Would you be able to print me a Go pro mount for a Solar Storm X2, I will happily bung you a £10 via PP.
Posted : 16/09/2016 9:08 am
No problem, made one for myself. my email is my username @gmail.com
Looks like this:
Posted : 16/09/2016 10:08 am
have emailed you brother.
Posted : 16/09/2016 10:37 am
Hexhamstu - Would you be able to print one of these?
http://www.thingiverse.com/thing:627020
New helmet has a gopro mount, I can't find anything like this for mounting a torch. Considering all sorts of bodges but that mount is what's needed really.
Posted : 16/09/2016 11:20 am
I can have a go, send me an email. myusername at gmail.com
Posted : 16/09/2016 1:00 pm
e-mailed, thanks 🙂
Posted : 16/09/2016 1:24 pm
