I'm looking for some cranks on a new build trail/AM bike and can get a deal on some M985's. Are they likely to be much weaker than the M980's or equivalent XT/SLX offerings?
Posted : 28/08/2014 11:12 am
No different to 980s whatsoever, only difference is BCD (which is a pain if you ever want to run non-XTR rings).
No reason to think they'll be different from XT/SLX, unless you're looking at older SLX with steel pedal inserts.
Posted : 28/08/2014 11:22 am
I thought that would be the case. cheers
I'm going to run a wolf tooth chain ring so should be fine.
Posted : 28/08/2014 11:33 am
