M970 xtr shifters -...
[Closed] M970 xtr shifters - fitting matchmakers
 P20
[#1817876]
I've got some hope matchmakers to fit my 970 shifters to my tech m4, but i can't seperate the shifter from it's original mount. Bolt out, it slides along but won't seperate. Is there something blinding obvious I'm missing here? I'll blame it on being post nightshift if I am!!!
Posted : 20/07/2010 5:20 pm
You need to open the shifter up as there is a small screw holding it altogether from the inside. Remove the tiny bolts to separate the halves of the shifter and you should be able to get in at the small screw. Should be obvious when you do it
Posted : 20/07/2010 5:41 pm
 P20
That explains it, cheers.
Posted : 20/07/2010 6:07 pm
 P20
Just got around to trying to take the shifter apart. How do you remove the thumb lever? 😳 It seems that i need to remove it 1st. Circlip pliers? 😕
Posted : 04/08/2010 2:10 pm
 P20
Anyone? 😕
Posted : 05/08/2010 11:40 am
 P20
Anyone?
Posted : 12/08/2010 8:23 pm
You don't remove the thumb lever for a start. Let me look at mine. back in a mo.
Posted : 12/08/2010 8:35 pm
Have you not got the assembly instructions from Hope. Email them for a replacement if you don't.
Posted : 12/08/2010 8:41 pm
