M970 chain rings......
[Closed] M970 chain rings...help required
[#3259639]
can you fit 24T small ring to a 44, 32 set up. i note that the middle ring is engraved 44 32 22 and fear ive made a mistake ordering 24 instead of 22
Posted : 19/10/2011 8:24 pm
Yep. I have run 22t, 24t, & 26t without changing the middle ring. Now I run 22t, 36t & 44t which s good for me.
Posted : 19/10/2011 8:30 pm
i take it that it has to be a M970 chain ring. i tried another 22T, it wasnt spaced right and was catchin the chain?
Posted : 19/10/2011 9:10 pm
I don't use M970 (XTR) I have the M770 crank (XT) and I have a 22t Middleburn lower ring, 36t M771 Middle ring & 44t M770 Higher ring and never found mixing an issue?
Posted : 19/10/2011 9:17 pm
You can use other brands of chainrings with M970 cranks - I've used Middleburn - but will need spacers in some cases...
http://www.ukbikestore.co.uk/product/54/cridsd/i-d--outer-chainring-spacers.html
Posted : 19/10/2011 9:41 pm
