M776 XT wheel for D...
[Closed] M776 XT wheel for Disc brake....and UST
[#1933545]
Guys
Just a quick numpty question...
The specs for the Shimano wheels XT and XTR all say something about UST compatible (23.3 mm wide UST Tubeless and tubed tyre compatible rim for use with 1.5 - 2.25 inch tyres)
Does this mean you can be used with no rim strip (like Mavic) and also with Mavic valves?
Many thanks
Posted : 26/08/2010 11:17 am
The wheels should come with specific Shimano valves, don't know if Mavic ones are the right shape to seal properly. You can mount a UST tyre straight onto the rim and run tubeless without any additional strip.
Posted : 26/08/2010 11:36 am
I have the 775's and they work much better than the Mavic UST rim I have, you can almost manually blow the tyre up on the rim without sealant, unlike the mavic which needs a flamin CO2 cartridge to do the job. The valves should be the same but they are only a couple of quid anyway....good wheels IMO.
Posted : 26/08/2010 11:40 am
Right then
Anyone want to buy some Stans ZTR355 on Hope Pro 2 with valves and rim strip. Two months old ridden a handful of time. Perfect condition!
Shimaon here we come
Posted : 26/08/2010 12:23 pm
 Stu
You can use the 355's without a rim strip too, just the yellow tape. I do anyway!
Posted : 26/08/2010 12:48 pm
