M4 countersunk bolt...
M4 countersunk bolts and brass washers, today
[#13237538]
Halfords or Screwfix or A. N. Other?
Posted : 28/04/2024 12:21 pm
As in brass countersunk washers?
Posted : 28/04/2024 12:23 pm
Sorry, no, as in stainless steel hex 15mm bolts (countersunk), and plain brass washers because I'm a tart.
To mount one of these in order to fit two bottles in available space. Need longer bolts than it came with.
https://www.ebay.co.uk/itm/355514002977?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=oJzMwxynSea&sssrc=4429486&ssuid=AOH8sI9PQZW&var=624659757609&widget_ver=artemis&media=COPY
The washers are when it's not fitted.
Posted : 28/04/2024 12:26 pm
Check availability in local stores,  reserve/order online if possible, collect.
Posted : 28/04/2024 12:32 pm
Thanks, I was just being lazy.
Posted : 28/04/2024 12:33 pm
Screwfix will have the M4 countersunk machine screws, but you’ll be lucky to get m4 copper washers, unless you have a either a hydraulic or auto parts store that’s open Sundays.
Posted : 28/04/2024 12:40 pm
gecko76 and gecko76 reacted
M4 ?
Are bottle mounts not M5?      (Goes to check)
Countersunk...does not need washer?
Confused.
Posted : 28/04/2024 12:49 pm
 cp
You'll need M5 screws to mount it to the frame.
Where do you want to put the washers?
Posted : 28/04/2024 12:54 pm
As above - M5 not M4.
Toolstation has stainless M5 x 16mm hex key countersunk screws and stainless washers. CSK screw length is usually overall length including the head so make sure these are long enough.
Posted : 28/04/2024 12:56 pm
https://www.ebay.co.uk/itm/282732204333?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=pWibwPPtQii&sssrc=4429486&ssuid=AOH8sI9PQZW&var=&widget_ver=artemis&media=COPY
These are what's going in the (bamboo) frame. Mind playing tricks now but pretty sure it's M4 (left them at home). Will get both.
Posted : 28/04/2024 1:13 pm
M5 it was, 16mm was enough and Toolstation good.
[url= https://i.postimg.cc/SssNHHJn/PXL-20240428-121123681.jp g" target="_blank">https://i.postimg.cc/SssNHHJn/PXL-20240428-121123681.jp g"/> [/img][/url]
You might be asking why not strap it in the same way as the one on the seat tube. To which I can only respond, yes, but aesthetics innit. Used some of those screw-in inserts before which worked for a few years. I'll be happy if the frame makes it until 2026 which'll be ten years of much use and abuse.
Posted : 28/04/2024 2:19 pm
Show us the bike then, looks interesting.
Posted : 28/04/2024 6:54 pm
An early incarnation
[url= https://i.postimg.cc/xdfp4FwN/20170417-145653.jp g" target="_blank">https://i.postimg.cc/xdfp4FwN/20170417-145653.jp g"/> [/img][/url]
Last summer
[url= https://i.postimg.cc/KYcpggQT/1690045130646.jp g" target="_blank">https://i.postimg.cc/KYcpggQT/1690045130646.jp g"/> [/img][/url]
Posted : 28/04/2024 7:21 pm
Did you swap out the seatpost??
Posted : 28/04/2024 8:08 pm
Yep. The seat tube cracked a couple of years ago and while it was fine in a fibrefix bandage, I eventually worked up the courage to cut it out completely and bond a cf tube in. And it worked! Well, there's things I'd do differently if I had to again but so far no shards in my arse and the ride is as smooth as before so call that a win.
Posted : 28/04/2024 8:15 pm
