Lyrik Ultimate wipe...
[Closed] Lyrik Ultimate wiper seals
[#11239783]
About to do a lower leg service and as its at 100hrs roughly I thought I would change the wipers too. Is there a seal kit that suits or is it the 200hr kit only? The spare parts catalog only lists the full kit as does the service guide.
Lots of 35mm seals on Ebay but I think they are for the older forks, no point putting non-low friction in.
Come 200hrs they'll go to TFTuned or similiar.
Also, I have Stendec Easyglide fork grease. Worth getting the proper Rockshox Dynamic seal grease or fine as is?
Posted : 09/06/2020 12:37 pm
I'm in a similar position as about to do a lower leg service, change air spring and upgrade the damper to Charger 2.1. It looks like the Ultimate uses SKF wiper seals which are a fair bit dearer than the standard RS wiper seals (£27 compared to £15). Looks like you can buy just the SKF seals from TFT and bearing suppliers.
Posted : 09/06/2020 2:02 pm
Bought theses, the box image is slightly misleading
https://simplybearings.co.uk/shop/p309657/SKF-MTB-Fork-Seal-Kit-Rock-Shox-35-Forks/product_info.html
took the cheap postage option and they arrived next day, not sure what you get for the more expensive option
Posted : 09/06/2020 2:10 pm
ZyroFisher now list ultra low friction 35mm upgrade kits, but they are currently out of stock, RRP £23.00, Current ETA 19/08/2020.
As well as the standard 35mm ones (also out of stock)
Posted : 09/06/2020 2:32 pm
Cheers. I've ordered these Ebay efforts so we'll see how we go, and look at the newer offerings next time.
Posted : 09/06/2020 3:08 pm
