Lyrik ultimate volu...
[Closed] Lyrik ultimate volume spacers
[#11376218]
How many are people running? Just to give myself a starting point..... I previously ran 2 in my 2017 Pikes but they are a different ball game. Im just looking to cut down tinkering time. All ideas will be greatly appreciated.
Posted : 11/09/2020 8:19 am
160mm at 95 psi 190lbs rider - zero tokens
Posted : 11/09/2020 8:22 am
170mm 29er, 68psi, 165lbs, LSC/HSC fully open, no tokens.
Posted : 11/09/2020 9:01 am
160mm 29er, 143Lbs, 60psi HSC open, LSC 4 clicks from open, 3 tokens
Posted : 11/09/2020 9:19 am
Maybe we should add which spring we're using. Mine is a C1.
Posted : 11/09/2020 9:27 am
170mm 29er, 200lbs rider, 92psi, Open compression, rebound 7 clicks from closed, 1 token
Posted : 11/09/2020 9:32 am
All depends on what travel they are. They go all the way to 180 so it can make a big difference as the token's main purpose is correct for air spring changes. For me it would be 180/170 No tokens, 160 maybe 1, 150 definitely 1, 140 maybe 1 maybe 2.
Posted : 11/09/2020 9:58 am
Sorry forgot to put that... 160mm 27.5
Posted : 11/09/2020 1:36 pm
160mm 27.5 C1 airspring. No tokens, 90psi @ 87kg bodyweight
Posted : 11/09/2020 3:15 pm
