I've a set of 2020 lyriks ultimate. The low speed compression should have about 12 clicks of adjustment, however this has reduced almost out of the blue to 5 clicks. Anyone on here have any idea why this could have happened? And what could be done to remedy the situation?
I had something similar when some dirt got trapped in the adjuster.
I thought it could be that but I've stripped it and it's clean as. May try a bleed to see if there's air bubbles!
Same thing here, mine sounds worse though. The LSC knob will now only move half a turn and not click at all. I’ve taken both compression knobs off and they’re both clean. HSC still adjusts normally. Not too fussed at the minute as they’re still working perfectly otherwise & I don’t often adjust the compression but they’ll have to go back to zyro on warranty at some point.
My dvo diamond did something v similar last year and sorted it self after a couple of months. So I'm wondering if there's a perhaps a rogue bubble somewhere
