I'd like to convert my Lyrik DPA (2013) to U-turn coil. Any tips or anything I should know about the conversion?
I've pulled this list of parts off an old thread on another site. I'm wondering if anyone can confirm that these are the parts I need to convert a 2013 Lyrik as I don't know if there have been changes along the years?
11.4310.717.000 u-turn travel adjuster Knob aluminum (Coil) Lever
11.4015.098.000 Lyrik u-turn Spring (choose the right one based on your weight.
11.4015.458.010 Lyrik Coil/u-turn top out assembly
11.4015.205.000 Domain/Lyrik upper tube/Spring Sleeve
Thanks!
Bump for the daytime crowd.
have you had a look on youtube? there 'may' be something there
best o luck
Lyrik Uturn parts have been delisted by rockshox so no longer available, it's second hand I'm afraid for the coil springs
the u-turn springs are very rare since a while..
even in the second hand world ...
was searching for a soft lyrik u-turn spring after converting my old lyrik from 160mm to 170mm with an spacer..and it took quite a while until I found a shop wich had one left...
We have all the other parts in stock (for the moment) just not the spring BTW
Ahh that's a pitty Loco, I thought from you're email that you couldn't get hold of any of the bits anymore so I hunted them down yesterday elsewhere. Managed to get everything new but the firm spring was an ebay job. Think I did well to get one looking at the number of wanted ads on pinkbike!
Out in interest anyone know if its solo air/DP air only for future Lyrik/Pike travel forks? Airsprings don't seem to work for me (92kg in kit, and shifting). Killed 3 forks air springs in the last 2 years, converted 2 of them to coil, but it is a bit of a worry if this is going to become hard.
