just changed the spring on my lyriks
when I wound the travel out to full it will not wind in again
have taken it out 3 times now and it moves freely when not in the fork
am I doing something wrong or is there something wrong with the new spring?
quick update
the travel adjuster won't turn clockwise at all
tried re-assembling with the travel wound right down and anti clockwise (increasing travel) its fine, but will not budge clockwise
Have you got the allen head screw at the bottom of the fork tight ?
yes, its really tight
its got to be something to do with the new spring assembly
put the old one back in and its fine
looks like thats another £40 down the swanny, got it from the states
3 springs and ball bearings all present and correct? Maybe the o-ring under the cap is missing? The fork bounces ok? The floodgate is turned off???
all springs and ballbearings in, o ring on the cap is there, the fork bounces ok but the adjuster will not move clockwise
I really don't get it
put the old spring back on in exactly the same way and its fine
I always get odd things happening to my bikes and vehicles 🙁
How do the springs compare to each other side by side, can you see any difference, to how they are put together, may give you a clue...
Is the new spring wound fully out or in?
Tried the spring both fully out and in, doesn't make any difference. Springs look pretty much the same except the new one has a black plastic insert as the travel adjuster, the one I took off was white. I really don't get it as when the spring isn't in the fork the plastic thing moves freely
You are looking at the wrong end! When in the fork the black plastic unit does not turn, the whole spring does. what you need to do is ensure that the top uturn assembly is free.
Remove the uturn spring, rebuild the uturn top cap with springs and balls, Soft jaw the bottom shaft in a vice, hold the threaded part of the uturn with your hand wrapped in a rag for purchase and turn the uturn assembly. If it still wont turn then there is something wrong in the uturn assembly, send the spring back if you bought it new. Or just leave it wound out.
Right, I've put the old spring back in so it shouldn't be too much of a faff to try that with the new spring. Just been looking at the shops feedback on eBay usa, doesn't seem they have an exemplary record for honouring returns, wish me luck!
why is there a circlip included in the spring kit?
isn't that in the lower leg of the fork?
How big is the circlip
jools182 - Memberwhy is there a circlip included in the spring kit?
Yes, it's identical to the one already in there - it's just a spare.
It holds the small top out spring in place in the stantion.
There is a tiny c clip holding the uturn top cap on.
its a great big jobby, its got to be from the lower leg
Jools it's for the top out spring in the bottom of the stantion. Don't worry about it, unless you loose the one already there you won't need it. Did you try the check I mentioned above?
not tried it yet as I don't have my own vice
need to get it to my brothers house
this is properly doing my head in
spring and u turn knob move fine when not in the fork, as soon as its assembled it will not budge clockwise
just tried taking the plastic spiral shaped adjuster and bottom metal rod off my other spring, and still the same thing
old spring seems to be fine
think I finally sussed out what was going on
the bottom end of the spring wasn't finished properly, and a s a result, it was digging in the to bung thing (I don't know the name for it) inside the fork that the spring sits on to
got a new spring and it worked fine
