Lyrik solo air - Se...
[Closed] Lyrik solo air - Set and forget setup??
 J273
[#3427690]
I weight around 68kg with all my gear, have the shock set with around 25-30% sag and it feels ok dont know the exact PSI im running but its not much,I use all the travel but still unsure on what sort of compression damping i should be using?
For anyone who weights roughly the same as me with the solo airs give me a good allround set and forget setting for the fork?...mine are the RC2 DH version of the fork.
As said they feel ok but for example when i go cannock which is my main spot the upper cliff black section theres a few bigish drop offs that need to be rolled off rather than dropped off as there just not enough entrance speed to drop/jump off them and the forks dive and about throw me over the bars and the same for a local spot i ride with them being set with a low PSI to use all the travel.On a steep section when i dab the brakes the forks dive and again feel as though its going to throw me over.
Can anyone give me some good HSC /LSC and rebound settings to try ,ideally to dial in and forget.
Thanks
Posted : 05/12/2011 11:32 am
4-4-1 is the usual recommended start up setup
4 high
4 low
1 of the silver dial on top??
Posted : 05/12/2011 12:41 pm
 J273
Ive been using 4 and 4, mine dont have the floodgate but im still finding them diving probably because of the pressure i have to have them set to to use the full travel of the fork.
Posted : 05/12/2011 2:38 pm
