Lyrik coil weights,...
[Closed] Lyrik coil weights, what do you use?
[#5524980]
Trying to decide between two forks for my Scott Voltage and one of the main deciding factors is whether or not I can get the right spring weight for me with a coil fork! I'm about 74kg and rarely ride with a backpack adding extra weight. According to the RS chart I should be ok with a medium/standard spring but I had a Domain on a different bike and the standard felt pretty hard and didnt have amazing small bump sensitivity, yet I feel that one down would probably be too light as the sag wasnt too far off. Could just be down to the compression controls, or lack of, on the domain..
The other option i have for a similar price at the minute is an air Totem which I can obviously fine tune to my weight but I'm not sure I need or want the added weight or travel, plus the main reason I want to change my current fork is stiction which could obviously be an issue with an air fork.
So, what are you using and how does it feel for your weight?
Posted : 17/09/2013 3:22 pm
same weight as you and run the medium
Posted : 17/09/2013 3:23 pm
