Lyrik Brake Mount
[Closed] Lyrik Brake Mount
[#11377506]
Does anyone please know the standard brake mount size on the 2021 Lyrik? I'm assuming that its 180mm and if I wanted 200mm then I would need to run an adaptor?
I've looked on SRAM's site and it states the min and the max size of the rotor, but doesn't state the default or if it comes with an adaptor
Posted : 11/09/2020 9:43 pm
Yep, 180mm. Minimum size is what you get without an adaptor. Physically can't get smaller.
Very close to what I've done on mine. I'm using Hope E4 calipers with 203mm rotor. I'm using an H mount which takes 160mm post mounts to 183mm rotor. Same thing only my lowers and my rotor are 20mm bigger, if that makes sense.
Posted : 11/09/2020 9:49 pm
https://www.sram.com/en/rockshox/models/fs-lyrk-ult-c2
Seems to say 180 on there? I would concur owning a pair 8)
Posted : 11/09/2020 9:50 pm
Thank you both, saves me buying the wrong size rotor
Posted : 11/09/2020 10:33 pm
