Lyric Rebound Adjus...
[Closed] Lyric Rebound Adjuster ....Where From?
[#2873296]
I lost mine a few weeks ago, but do you think I can find one in stock anywhere...can I bu66ery. Anybody know of anywhere with one in stock, Domain and Totem also use the same one 😥
Posted : 21/06/2011 4:06 pm
You know it's basically a 2.5mm allen key and thus you can use any 2.5mm allen key right? (I might be wrong about the size, but it is just an allen key).
Failing that I have a spare one you can have. Donate something (amount is up to you) to Help For Heroes and I will pop it in the post to you.
Posted : 21/06/2011 4:13 pm
It's a few months since I took tools up against my mate's lyric, but i seem to remember the foot nut on the damper side being the same size as on the 32mm forks. Might be worth borrowing one from a recon/pike/reba/revelation to see if it fits.
[edit] or take geetee up on his kind offer ^^ and check the springy ring thing on the foot nut, which if too loose will let that one fall off too...
Posted : 21/06/2011 4:14 pm
geeteee....I should have said, I know what size allen key it is. I need a new adjuster so that I can sell the forks, as they are mint otherwise. More than happy to make a donation for the adjuster. Many thanks, will mail you.
Posted : 21/06/2011 5:01 pm
If you think you may have lost it at Cwmcwarn a few months ago, I have it alongside me, and you're welcome to claim it back.
Posted : 21/06/2011 9:19 pm
I did lose it in Wales, but at Llandegla, not Cwmcawrn. Thanks anyway.
Posted : 21/06/2011 9:41 pm
Lost mine off my new Lyrics at Glentress awhile back(only second time out 😥 )and looking for a replacement also.Happy to pay or make a donation if anyone has one going spare.E mail in profile.
Posted : 21/06/2011 10:02 pm
Just run the fork without it. Don't understand why you'd need to constantly adjust the rebound once you've got it set where you prefer it!?
Posted : 21/06/2011 10:33 pm
Thanks for that twohats,if only I'd known.All this time my bike has been lying idle in my shed unused for want of a missing rebound adjuster 😉
I'm not really a knob fiddler honest.I only really adjust my rebound from how I have got it set for trail riding when I'm doing bigger jumps and drops with added gnarr, then I like to run it a little slower.
Cheers for the kind offer coatsey,you're a gent.
Posted : 21/06/2011 11:17 pm
twohats....I need the adjuster as I am about to sell my Lyriks. But I do adjust it quite often, normally down to temperature on the day. Recent riding has varied in temp from 3-23 degrees. More notcable as my Lyriks are air ones....hot day oil gets thinner, air pres. increases = too fast rebound, adjust rebound to compensate...simples 😉
Posted : 22/06/2011 9:40 am
