I'm not much of a lycra wearer. I had an experimental phase with lycra shorts, as many young men do, and I wear padded undershorts but that is as far as it normally goes.
However I decided this year I'd get myself some 3/4 bib tights for my commute, thinking they'd be nice and warm in the winter and dry quickly if I got rained on.
So I went for these dhb 3/4 Roubiax ones:
http://www.wiggle.co.uk/dhb-vaeon-roubaix-padded-34-bib-tight/
They seem a bit tight though. How tight are tights meant to be exactly?
I was expecting something like "sock-tight" (i.e. close fitting but not stretched) but these feel skin-tight. I can get them on okay but the fabric is stretched tight.
My missus, more familiar with tight wearing than me, assured me that this was normal (once she stopped laughing) and according to the wiggle size chart I'm spot on for the Large which is what I got - but I know other dhb stuff is sized badly and I get the feeling these could have an extra inch width in the legs without being loose.
Worth returning and going up a size?
For your amusement:
oofft didnt need to see that in the morning
those do look a touch on the tight side....
Hairy legs and lycra? What are you doing.....
Seem not far off what mine are like. So long as they're not see through, no problem...
Well heloooooooo sailor! :-*
I've had the same with some 3/4 tights - they were also pretty tight, especially around the legs, where they don't seem to take into account for some of us with the bigger legs.
Seems that the uber priced brands such as Assos et al have different sizes within sizes for this very thing. I think.
>mindbleach<
I'm hairy all over. Like a real [s]monkey[/s] man should be.
If I shave my legs I'll look like I'm wearing furry boxers.
Do DHB use 'Italian' sizing? Don't own any bib tights, but I have compression tights, which (obviously) are tight, but not stretched, and my bib shorts always feel tight standing, but not noticeable at all on the bike, again, tight, but not stretched. I would guess that if the lycra is stretching then I'd be going with it's a bit small, but smaller is better than too big. Do they feel ok if you're sat in a riding position? If so, I reckon they're ok.
Yeah these are very much at the budget end (£40) to satisfy my curiosity.
If I decide to come out of the closet during daylight hours then I'll get some more upmarket ones.
Skin Tight or tight enough to tell if you have been circumscised
It wont last long as they will stretch anyway
Like the piccie wasn't bad enough. I think I just did a little bit of sick in my mouth.
But seriously, I look similar albeit with a slightly larger tum that requires hiding/holding in place with a tight top. You really wouldn't want to encounter me when out and about togged-up in riding Lycra...
Thread reported to mods 😀
Hang on, I'll get a close up and you can tell me...
OMG pissing myself..they are fine by the way there meant to be tight got to say your brave posting that on here
your dining area is in a right state (not a euphamism).
When you're blessed with a body like mine it is only polite to share it. 😆
That's it tidy. You should see the rest of the house!
2 year olds and fine dining do not mix well.
They are fine - DHB 3/4 are sized perfectly ime.
No point in buying Lycra and having it flap around like err shorts... is there?
Oh and don't post up any more pics like that before the watershed 😉
I'd want the fabric to be stretched but still have some give. If it's full stretch surely that's too tight? Can you fit a pair of socks down the front? Can you bend over and grab your ankles? Post up another pic in this position please 🙂
I wouldn't say it's at full stretch - but it's certainly stretched tight.
Other lycra I've worn has been considerably looser (e.g. MT500 lycra shorts)
Always do. The general scrotal area is fine - it's mainly across the thighs and calfs that feel tight. Also I can feel the shoulder straps pulling down.
Pffffttt... I'm a 37 year old desk jockey. I can't even do that sober.
Have you got on the bike with them yet?
My bib shorts are bloody uncomfortable when standing up but sublime when i'm on the bike, only got one pair so nothing to compare it to!
Nah, the missus dragged me to bed as soon as she saw me in them.
(also I didn't want to get them dirty cos I'm thinking of returning them)
Seem okayish when sat in a bike-like position - but still tight. Also they seem to bunch a bit behind the knees but that may just be because they are cheap.
Tight but not too tight, I think snug is the word
Let's face it the only reason for wearing lycra is comfort so....
Are they comfy to ride in?
yes keep em
no [s]diet[/s] bin em
They are not see through enough, there are no frilly lace bits and you are not wearing high heals.
What exactly is the point of the photo?
I want a refund.
How tight are they when you're not sucking in your gut 😉
GrahamS - bravest poster of the year!
I ought the identical tights in the same size after reading the size guide on Wiggle and yes I thought they were a bit tight. After a fe washes they loosen up a little but care needs to be execised with the crown jewels
Think it's worth going up a size while they are still new then FOG?
I'm concerned that the next size up (XL) says it is for a 41 inch waist which sounds massive, but if it gives me a more comfortable leg then may be a good plan.
Just avoid this particular brand, unless you want to look like the Terminator after a sex-change.
Is it me or does he have a bad case of cameltoe?
Well so far guys (As the standard of STW goes) quite sensible and disappointing. Where are all the 'good' and 'bad' fit pics? 😀 I'm ill at the mo and need cheering up
I prefer my bib tights to be excrutiatingly tight and painful.. I take a M/L but always buy an XXS..
Hot chilli sauce on the chamois too.. 😳
My theory on bibs is, if you have to extract the pad from your arse hole at the end of the ride, then the shoulder straps are probably a bit tight. (I have some Assos bibs that do this. Quite unpleasant).
as junkyard says, lycra gets baggier with use/washing/time so "sock tight" would become baggy in no time.
Having mixed results with my first forays into roadie kit and bibs. Got some Pearl Izumi Select (cheaper range) bibs in small, seem to fit okay, straps possibly a bit tight (no experience to compare them too but they pass the Pedalhead "floss" test 😯 ) but the actual shorts bit feel perfect. So splashed out on a pair of higher end Pearl Izumi Elite bibs, again size small, and I couldnt even get them over my knees 🙄
Fair play on posting the pic, any haterz should put up or shut up 😛
"Bad case of cameltoe" is putting it mildly. It's definitely more of a growler than a mumbler. 😯
that reminds me, I must pick up some new potatoes
Dear god no
Whenever I see that photo the first thing I see is their mismatched helmets.
*raises an eyebrow*
I've gone by the size guide Prendas gave me when I bought my first pair of bib shorts
It goes along the lines of:
"The waist size is pointless, that bit can stretch as much as you need it to. The size you need is in the height and leg length."
Followed that with the 2 bib shorts and 2 bib tights I have, and right enough they've coped with me dropping from 95 kilo down to 68 and back up to 75 as well as daytime bloating fine.
So, if the shoulder straps are digging in then you're probably a size too small.
IF they are feeling a bit tight on calves and thighs double check whether they are meant to be compression tights, and then don't worry about it, again that's a stretchy bit designed to be worn for leg sizes between Rasmussen and Hoy.
with lycra it should all be under a bit of tension. Unless you were the modle for the makers they won't be perfect but thats why its stretchy. If in doubt, which means you might buy either size, go down. It will always fit whereas if you go up it my be baggy which is wrong. thicker fabric has more potential to bunch behind the knee as do simpler designs which tend to be the cheaper ones. My DHB 3/4 bibs have given good service for perhaps 100 days a year for at least 4 years. without a doubt the only piece of clothing that gets more use are my wellies and then are not any longer lasting.
You ned to add some arm warmers to complete the look 😉
[i]Whenever I see that photo the first thing I see is their mismatched helmets. [/i]
I try not to look that closely, tbh.
"man uses size doubts as excuse to post pic and gets away with it"
shame on you!
