Lubes for suspensio...
[Closed] Lubes for suspension from CRC
[#3709141]
Along with the fork oil, I'm looking to get some suspension grease and some lube for the seals.
I've got some CRC vouchers and I'm thinking Rock n Roll super slick grease and rock oil suspension fluid. Any good, and any suggestions for the foam seal lube?
thanks folks
Posted : 23/02/2012 10:52 pm
What forks have you got?
You seem determined to spend money!
The rock oil stuff I like as the different weights are different colours and you can tell when they've leaked into each other.
For the foam rings RS recommend soaking in the 15wt oil. I've also used Fox Fluid - and havent died. I've never used grease on the seals themselves.
Following all that every 6 months or so - I've never had any worn stuff.
No experience of Fox forks - sorry.
Posted : 23/02/2012 11:13 pm
I just use the Stendec stuff. 5wt, 15wt and the grease. I like to use matching stuff and it's what my LBS use (I actually bought it from them not CRC!!!) so I know I can get some locally at short notice (or pinch a bit out of their workshop supply if it's not in stock)
Posted : 24/02/2012 12:21 am
