lubeing fork seals
[Closed] lubeing fork seals
[#3621338]
can i use tf2 extreme wet on my fox fork seals?
thanks
Posted : 29/01/2012 9:39 pm
no one?
Posted : 29/01/2012 9:55 pm
I'd go with Fork Juice.
APF
Posted : 29/01/2012 10:11 pm
I use fork oil.
Posted : 29/01/2012 10:13 pm
I use Halfords Silicone spray... nothing sticks to it !!
Posted : 29/01/2012 10:21 pm
Hi Gibbo,
If you have stripped the forks down and are wanting to soak the foam seals in something then Fox / Mojo recommend cleaning the rings in the same suspension fluid that is in the legs and then coating with fox float fluid.
If you just mean what to use after you have cleaned all the mud off the stanctions then Fork juice is good i've heard. TF Tuned recommended finish line Dry chain lube with Teflon and thats what i use. Clean the stanctions then put a line around the stanction just above the seals. Pump the forks 20 times then wipe the muck away.
hope this helps
Posted : 29/01/2012 10:30 pm
I use a Finish Line Wet Lube.
Posted : 29/01/2012 10:31 pm
