My Thomson stem (40mm) is a little high for my short steerer. I've tried a Race Face Ride xc which is 39mm and works a little better as the hole in the inner front of the stem is smaller, but some fo that is still exposed, and I'd ideally like something shorter.
http://www.chainreactioncycles.com/Models.aspx?ModelID=27534
On my last thread on this topic it came out that some FSA stems have 35mm stack heights, would the 190 below do so?
http://www.chainreactioncycles.com/Models.aspx?ModelID=34534
TIA - I don't want to return the Race Face if it is the lowest I can get.
Bah! I thought you could ask CRC a question but they seem to have removed the option!
[url= http://www.repartocorse.com/fsa-os-190-stem.htm ]This link says it's 35mm[/url]
Cheers Steve, different pic but the description is correct I think.
OK FSA is here. It's 40mm but the "hole" at the inside front is a lot smaller and so there's more reinforcement - RF is going back!
got a os140 and a os190, just measured the 190 and it is 40mm
and the fsa os140 is 35mm
