Just changed frames (from an old Iron Horse mk111 to a Heckler) and about to build it up. Before ordering a new headset I wanted to check the folowing : Ive gone from an integrated headset on the Mk111 to a standard one on the Heckler and Im concerned that a Hope headset at 31mm stack height is not going to give me enough steerer tube as I had cut steerer tube on the forks so as flush with stem and 1/4 inch spacer on Mk111. I dont want to be forking out for new forks so was wondering how much lower than the top of the stem can the steerer tube safely be? - or should I be cautious and go for a lower stack headset? - something like a Crank Bros Cobalt C XC. Any advice greatly appreciated. Cheers , Colin
I guess aslong as the top bolt of the stem clamps then its ok. Ideally 3-5mm below
As long as the top bolt is a few mm below the steerer it'll be fine. Use the above or even add a second star nut.
Try this[url= http://www.singletrackworld.com/forum/topic/low-sack-height-headsets-help ]another thread[/url]
I´m using the crank bros headset, low height, does the job, no problems.
