Assembled experts can any of you help me, I need the lowest possible stack height headset for my cove handjob as the forks I have have a very short headtube. Can anyone give me some suggestions and dimensions? I will also need a low stack stem to match! all help appreciated
Neil
Crank Bros headset at 21mm stack, FSA stem at 35mm stack
Thanks Nuke, which FSA stem is 35mm?
[i]FSA stem is 35mm? [/i]
Quite a few of them so I wasn't going to be too specific...get over to CRC and they say on some of the models e.g. http://www.chainreactioncycles.com/Models.aspx?ModelID=12715
I've just swapped a Race Face Diabolous for a Crank Brothers Opium C, Crank brothers is tiny! I couldn't find smaller that would fit a 'normal' frame.
2nd the crank bros-just fitted it to my intense 5.5 and it has saved the day with my fork steerer being too short
Try a Truvativ stem. Great quality and low stack. 🙂
Crank Brothers headset have the lowest stack around 21mm, I run a 1.5 sage on my Intense Tracer but it seized after only 6 months, the bearings in the lower cup are corroded and the lower cup has pitted, looks like ill be sending it back under warranty and do without my full suss for god nows how long... I know we have to service our bearings from time to time but i'd have thought they would have lasted longer than that.. I've had a hope headset for nearly 3 years never let me down and still going strong
Sunline V one AM stem has one of the lowest stack heights going, am in the same boat as it goes so the CB directset is also required... Westbrook Cycles are doing them for £45 BTW
Looks like its crank brothers then even if they are a bit dodgy craig
thanks everyone
Personally I'm not confident of my CB headset lasting but at least it does come with a 5 year warranty and 2Pure are excellent to deal with.
Yep, that sold it for me....
I think I just expected a bit more out of £90 headset...
Well yea, you would, but when they are £45 it's a little easier.
