Low Spray Commuting...
[Closed] Low Spray Commuting Tyres, do they exist?
[#2861028]
Does anything like this exist?
I use my old Kona single speed for commuting and have mudguards on it. I quite fancy being able to quickly swap wheels for the days I want to ridi in off road but I don't have the clearance to do this with mud guards. Does anybody make a commuting type tyre for 26in wheels that reduces spray and therefore mitigates the need for mud guards?
Posted : 17/06/2011 12:45 pm
You'll get (copious) spray off anything, slick, low profile knobble, you name it.
I get this issue swapping between my 32c slicks and 35c spikes in winter. I have to run my 'guards at full extension for clearance. Looks utterly gash when I put the slicks back in, but there is no other way unless I have the time and inclination to mess about adjusting 'guards every other trip.
Other options would be snap-on 'guards, like race blades. But they often don't go big enough, and are hopeless compared to proper guards anyway. On a 26" would a front and rear crud-esque set of 'guards keep enough spay off you? Its often the spray off the front filling your boots which is the worst IME, and a front crud does chuff all for that.
I live with the fact my commuter isn't the most fashionable bike around. It gets me to work.
I have, however, often wondered if I could figure out a better mudguard mounting system, so it would pop between settings.
Posted : 17/06/2011 12:53 pm
I'd sort of want the tyre to move the water TBH
All you can do is redirect the spray
Posted : 17/06/2011 12:55 pm
Thanks Dead Hero. As you know, any 'real' commuter uses nothin less that full length guards. Proper commuters are nearly always function over form.
I guess I'm looking for the impossible. Might just have to get another bike instead.......
Posted : 17/06/2011 1:38 pm
