low sack height hea...
[Closed] low sack height headsets help
[#487452]
i need to loose a few mm off my headset height to fit my current forks to the new frame. Can i fita zero stack headset into a normal frame?
if not what headset has quite low stack height i was going to usemmy orbit xl2 but adly not enough length on my steerer tube
ta
Posted : 20/04/2009 8:33 pm
As I understand it, a zero stack headset will only fit into a frame designed for them, but I forget where I've see the reason why. I think it's just the difference in height for where it slots into the headtube.
Posted : 20/04/2009 9:08 pm
 momo
zero stack headsets will only fit into headtubes that are designed for them, as the bearing sit inside the headtube.
as far as normal style headsets, you could try the crank bros ones, I think they have the lowest stack height out there.
Posted : 20/04/2009 9:13 pm
Zero stack headsets have a bigger "hole" in the headtube as the whole cup sits within the tube rather than hanging out the top and bottom.
I think that the Crank Bros ones are low stack, no idea if they're any good though.
EDIT - too slow!
Posted : 20/04/2009 9:16 pm
There is
[url= http://www.balfa.co.uk/catalog/product_info.php?products_id=152 ]acros[/url]
also
[url= http://www.extralite.com/index_euro.htm ]extralite[/url]
both have sub 25mm stack
Posted : 20/04/2009 9:46 pm
