Evening
My bronson seems to eat lower shock bushes, changed it last month and already in need of replacement.
Has anyone used the TF tuned low friction bushes? as fox ones are just a tad expensive from mojo at the rate there disintegrating
link to tf tuned bushes : http://www.tftuned.com/low-friction-mount-kits-127mm-m8/p2928
cheers ditch
scratch that just seen the tf ones are a different size
Are they like a polymer flanged bush...? Do you need any other parts?
If you need just a flanged polymer bush, they're probably made by IGUS...you might be able to get them direct if you measure up the ones you have...?
http://www.igus.co.uk/iPro/iPro_02_0001_0000_GBen.htm?c=GB&l=en
I've found the cream coloured ones from Mojo or Jungle have always last the best. I had some red ones once from I think TF Tuned and they didn't last long at all.
If it's eating them quick it's worth checking there isn't any play in the pivots as that seems to destroy them quickly. Also worth checking the mount kit isn't worn if you're just changing the bushings.
stumpy
Thats awesome thanks ill check them out maybe worth a try
smatkins
I've been using the cream coloured ones from mojo, however just gave the bike a complete overhaul this week too because i was thinking the same new pivot bearings 8 in total and new headset bearings, and rear hub bearings shes had the lot the pivot where it bolts to seems to be okay and so do the fasteners
anyone heard of the main pivots wearing out ?
