Losing Oil through ...
[Closed] Losing Oil through U-Turn Adjustment on Pikes
[#414149]
Has anyone else lost fork oil through the U-Turn adjuster/Schraeder Valve on a Air U-turn set of Pikes?
I lost about 1 teaspoon maybe less whilst the bike was lying down in the back of the car for a couple of hours.
Can you top it up easily and can you sort the root cause of the issue easily at home?
Posted : 23/03/2009 12:31 pm
Call Tim Flooks?
Email RS?
Posted : 23/03/2009 12:41 pm
This happened to my Pikes when they were still under warranty, it was an 'O' ring that needed replacing I believe.
I can't give you more detail than that as sadly the Girly white noise effect occurs when people start telling me some of the finer details of technical stuff....
Posted : 23/03/2009 12:45 pm
This happened with my Rebas when I used to leave the bike upside down in the shed. I am not sure how much I lost, but it hasn't affected the performance as far as I can tell and I know make sure I store the bike upright.
I might e-mail Rockshox as it does seem a little crappy.
Posted : 23/03/2009 1:00 pm
It's in the FAQ bit for Rock shox on the tf site. O ring issue, they have a mod which improves but doesn't remove it.
Posted : 23/03/2009 1:19 pm
 lrd
I have this through the u-turn on my 09 revs. The bike was upside down for 2.5 hours in the back of the car driving to Brechfa. The distributor said I could return them for a new seal under warranty.
OK, so this is vaguelly normal...
I'll get them serviced in the next month anyway.
Cheers All.
Posted : 23/03/2009 1:24 pm
the oil in the spring leg doesn't really do much other than lube the seals. There is a circlip which holds the u-turn bit on, take this off (beware the ball bearings and sprinds which give the adjuster the 'nothces') and replace the o-ring underneath it, job done. Not worth paying £10 postage to replace a 10p part IMO.
Posted : 23/03/2009 1:43 pm
