Lordswood Thursday ...
[Closed] Lordswood Thursday night ride
[#7796754]
The norm.
Posted : 28/04/2016 1:05 pm
Me!
Might take an early wander up to trail maintain or just play
Posted : 28/04/2016 1:06 pm
yep
Posted : 28/04/2016 1:29 pm
yeap
Posted : 28/04/2016 1:35 pm
Yeap, might try to squeeze in some power time before maybe not an hour though and maybe not that much power.......
Posted : 28/04/2016 1:43 pm
Probably
Posted : 28/04/2016 3:26 pm
The second half of the trail dwon from the Bomb hole has a small diversion and a bit of trail clearing. You cross the fire road after the climb up from the old jump spot and it starts with a rooty section.
At one point the trail used to turn left into a dip full of deep mud. Now there is a right turn before the mud dip and you rejoin the old trail about 10 metres further on. Also the branches blocking the trail by the fallen tree a bit further down have been cleared.
A bit of drainage on the clay section directly across the clay crossroads just after the bottom of slayer means it is now nicer to ride straight on than try and negotiate the swamp if you turn left. Also taken the end of the tree that was blocking the trail if you turned right.
Turning right past the now shortend tree leads to quite a nice little trail from the corner opposite where Lordscrew used to start. This runs down the hill to the end/start of No Dabs.
The little trail between the path and the stream has had some foliage cleared so is rideable avoiding the deepest mud.
A couple of the more flooded crossings on No Dabs have been drained slightly.
The big flooded area where three deep puddles seem to have joined now has a semi-rideable trail close up to the edge of the stream.
I will see what else needs a little polishing this evening
Posted : 28/04/2016 4:18 pm
In.
Posted : 28/04/2016 5:19 pm
